Advice on this spec please.
mike.s
This is my first venture into this forum and would like your considered opinion on the following spec. I use the pc for general application work, internet use, quite a lot of photo work, a little video editing, never any games. I have tried to keep the cost down but at the same time keeping the machine a little future proof, if that is at all possible! Does this case have a firewire connection on the front.
Intel® Core™i5-760 Quad Core (2.80GHz, 8MB Cache) + Turbo Boost
ASUS® P7P55D-E: USB 3.0, SATA 6.0GB/s, CrossFireX™ SUPPORT
1GB ATI RADEON™ HD 5450 PCI EXPRESS - DirectX® 11
INTEL SOCKET LGA1156 STANDARD CPU COOLER
4 PORT USB 2.0 INTERNAL PCI CARD + STANDARD USB PORTS
Firewire & Video Editing
3 Port IEEE 1394a Firewire PCI Card (£9)
Standard Build - Approximately 9 to 13 working days
Price: £645.00 including VAT and delivery.
Sleinous
photo and video editing? Phtooshop? If so you may experienece a more enjoyable usage if you go for an Nvidia GPU in this instance and download the CUDA plugin for your work. a GT 430 or GTS 450 would be more than sufficient. Good choice on CPU, and RAM. 64mb cached drive is also a good choice. Nothing in this rig seems worthy of a modification :)
PCS
Administrator
Staff member
Welcome to our forums :)
This is a well balanced PC you've put together, but unfortunately the case will not have a front firewire port.
