Advice on this gaming PC
Four Dyce
Hi all. I've bought my previous PC from PCS about 2 years ago now, but it's getting a bit creaky. I have managed to save about £2000, so that's the top end of my budget. I want to make it as future proof as possible. Going through the Build Your Own - Desktop options, here is the first try. I also have some questions later.
AMD Based System
AEROCOOL SYCLONE II MID TOWER GAMING CASE
Processor
AMD Bulldozer Quad Core FX-4100
ASUS Sabertooth 990FX - TUF Series Military Grade Motherboard
Memory
8GB Kingston Hyper-X Genesis Dual DDR3
3GB AMD Radeon HD7970
1st HDD
250GB Intel 520 Series SSD, Sata 6 Gb/s
2nd HDD
1TB Seagate Barracuda Sata 6 Gb/s
Blu-ray Drive
12x Blu-Ray Rom Drive, 16x DVD +R/+RW
Corsair 850W Enthusiast Series TX850 V2-80
Coolit Eco II Fatboy Push/Pull Config Liquid CPU Cooler
Creative Sound Blaster X-Fi Titanium
Plus all the other bits and bobs you can choose from like the fan controller, PCS Extra Care delivery and the Fast Track 5 Working Day Dispatch, the total cost including VAT comes to £1.690. I don't need a monitor, mouse and keyboard as I already have those. But with the money left from a budget of £2000 I can buy them near where I live anyway.
1 - What is the main differences between an Intel and AMD based system? Bearing in mind it's a gaming machine.
2 - Any thoughts on graphics card? I've chosen a HD7970 but I was also considering 2 HD6970's. Which would perform best?
3 - I don't think I need the 6 or 8-Core processors do I really? I think dev's are only just making use of 4-Cores really.
4 - Would the case and motherboard have room enough for SLI/Crossfire? Not for now, maybe in the future.
5 - I've wanted an SSD for a while, but are they any better than just a fast HDD? But I also heard they can break down faster.
Well that's all the questions I can think of for now. Thanks for any advice.
Music Guy123
1. Intel are faster and I think better built. But they come with a price tag. I would highly recommend an i7 2600.
2. 1 x 7970 will blitz any current game, however, make the spec future proof so that you can add another later when one starts to struggle on its own.
3. You don't, 4 cores will be fine. I would get an i7 2600 as it comes with hyper threading which will give virtual cores if you need it.
4. The mobo will, I would possibly upgrade the case but your choice should still be fine if you really like it.
5. I would definately recommend an SSD, especially with a budget like that.
Music Guy123
You also probably shouldn't need the sound card. I would get this spec:
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V/GEN3: PCI-E 3.0 READY, SLI, CROSSFIREX
3GB AMD RADEON™ HD7970 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
120GB KINGSTON HYPERX SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£69)
CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® SILVER MODULAR (£159)
COOLIT ECO II FAT BOY PUSH/PULL CONFIG LIQUID CPU COOLER (£79)
Price: £1,701.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-sandy-bridge-pc/
bg92
Expert
Power supply is overkill. A hx750 would be a better choice. I would put the money saved towards a better case and a intel 520 series ssd instead of kingston hyperx ssd.
Four Dyce
Thanks, yeah I did like the look of that case. However....I also liked the look of the NZXT PHANTOM 410 White Gaming Case. Also the dimensions are bigger.
I thought computers performed better with a dedicated sound card. Takes some load off the processor? Actually I could also take the sound card out of this one as it's practically the same one, and put it in the new one.
Lastly could I get away with a 850w PSU, instead of that 1050w?
Edit: bg92 got it in before me. So a 850w should be fine?
TJWhonley
not sure if you sli 7970s it will be good enough for 1 tho try putting 2 in your spec and then seeing if you have enough power by pressing proceed
Four Dyce
You're not sure if Crossfire HD7970's will be good enough?
Edit: Oh wait hang on, I know what you meant now, sorry. I was being dumb. It tells you after you click proceed whether the build has the power to run the components? Well I don't plan on 2 cards yet, I'll probably just stick to 1 for now. What I wanted to make sure of was the mobo and case that if in the future I need another card it will fit.
bg92
Expert
When it comes to soundcards, they do make a difference, but only really useful if you are planing to use high end speakers, and want very good positional audio.
btw this is what I would go for, maybe with a soundcard either SB Recon3D Fatal1ty Pro or SoundBlaster Recon3D PCI-E
NZXT PHANTOM 410 WHITE GAMING CASE
Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
CORSAIR 750W PRO SERIES™ HX750-80 PLUS® SILVER MODULAR (£116)
Price: £1,600.00 including VAT and delivery.
Four Dyce
I have Logitech surround sound speakers, so I think I'll need to get one, or use this old one.
I'll try that build, maybe add and tweak it a little, but the main components are going to be the same though.
Edit: Yes that is a very good build, with a soundcard and 1 or 2 other bits it comes to £1.664.
tom_gr7
Life Serving
that spec is pretty ace! couldnt faulty it!
@four dyce, how do you're sound system connect up? analogue? Optical cable?
Four Dyce
It's the three connectors in the back of the card. Black, red and green are they? Something like that. (Colourblind)
Well, I've done it :yes: Went ahead and ordered it. Phew, for some reason I always get nervous when placing an order online like that.
Thanks for all the advice guys, it really helped :) Gave you all some rep.
