Hello,
Buying a new PC for web development work, multitasking across 3 monitors – very heavy web browsing, VS Code/IDE, Adobe Photoshop, Excel, Slack/Teams/Zoom + other background applications & multimedia.
Secondarily I want it to be capable of playing all the latest games throughout its lifetime. My current PC lasted me 8 years so would like it to last that long again. I don't need it for highly competitive online gaming or extremely high settings, as long as it comfortably runs whatever I want it to for the lifetime of the PC and looks decent. My current monitors are 1440p and I'll be happy to get 60fps.
Budget:
£1800 is the upper end of what I wanted to spend, but I could stretch to £2000 if there was a really good reason to.
Current Monitors:
1 x Acer Nitro XV271UM3 24" 1440p (IPS, HDR, DP or HDMI, FreeSync, 180Hz)
1 x Acer CB270HU 27" 1440p (IPS, DP or HDMI, 60Hz)
1 x Acer GF246 24" 1080p (TN, DP or HDMI, FreeSync, 75Hz)
Questions:
LIAN LI LANCOOL 205 MESH C GAMING CASE (includes 2 x Front 140mm PWM Fans and 1 x 120mm Rear)
AMD Ryzen 9 7900 12 Core CPU (4.0GHz-5.4GHz/76MB CACHE/AM5)
ASUS® TUF GAMING B850-PLUS WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
96GB Corsair VENGEANCE DDR5 5200MHz CL38 (2 x 48GB) KIT
12GB ZOTAC GEFORCE RTX 5070 SOLID - HDMI, 3 x DP
2 x 120mm Thermaltake TOUGHFAN 12 Case Fans
ONBOARD 2.5Gbe LAN PORT
NO OPERATING SYSTEM REQUIRED (will be using Windows 11)
Price: £1,792 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/8GXYMdnuPa/
I went for the RTX 5070 over the Radeon RX 9070 as I thought having the best driver & software support + CUDA with Nvidia would be make it the best all-rounder, good for things Photoshop and potentially for running local AI tools / LLMs in the future (very hypothetical); but I may be putting too much weight on that vs having the 16GB VRAM with AMD and could be convinced to swap. I'm sure either would be suitable. My monitors support FreeSync (not Gsync) but I think Nvidia supports this? Likely not a dealbreaker for my usage.
Budget:
Current Monitors:
Questions:
- Is the CPU cooler adequate and the 2 extra case fans a good choice? I'm not planning to overclock or tinker and want it to last, prefer not to have liquid cooling.
- I want to plug in a SATA SSD with minimal effort - should I put this in the order notes or is it standard that they would leave cables etc in place for that?
- Slightly confused by USB options but am I right in thinking I get 10 slots on the back (per motherboard spec), or if I choose the +2 or +4 options it uses up a PCIe slot to give me 12 or 14? (+ the 3 on the front of the case)
- The tool said I only need 650W power supply but for £12 difference I figured 750W would be more efficient - is that just wasting money though as the tool suggests? The only hardware changes I'm ever likely to make are RAM and SSD drives.
- Motherboard comes with external WiFi antenna you plug into the back? This worked well on my current z270e and I do need WiFi.
- Added thoughts on graphics card below.
