Configured this build for my son. He games at 1440p, 165hz.
He also does a lot of compiling and rendering.
What are your opinions on the balance of this build to work for 1440p gaming and also for productivity/rendering?
Any suggestions to improve on my configuration very welcome.
Max budget would be 3700. His main aim is to increase the speed of map/level compiling.
For multi- core applications, 5900x or the new 12th gen Intel CPU's?
PCSPECIALIST.IE SPECIFICATION
The specification below has been formatted so you can easily copy and paste this to our forums when discussing your specification. Once you've copied the specification, please click here to continue.
10GB ASUS TUF GAMING GEFORCE RTX 3080 - HDMI, DP, LHR
Corsair iCUE H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
LED Lighting
50cm ARGB LED Strip
4x Corsair LL120 RGB LED Fan + Controller Kit
ASUS PCE-AX3000 Wi-Fi 6 (802.11ax) 2400Mbps/5GHz, 600Mbps/2.4GHz
Microsoft® Edge
Price: €3,662.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/amd-am4-gen3-pc/G!dmw6GHxR/
LED Lighting
50cm ARGB LED Strip
Microsoft® Edge
