hi all, I’m not too savvy so not completely sure if this is half decent, or if I should change anything? I am on a bit of a budget, I guess im looking to spend under £1300
Based on what I know, I think the 12400F is pretty decent, so guess that doesn’t need changing
motherboard, it’s set as the default, don’t know if that needs changing?
gfx card, 4060Ti 16gb or the 3070l or the 3060TiI guess the 4060 is a little better.. but is the price difference worth it? Not sure on that. Perhaps I should just go for the 3060Ti..
wireless network card is 300mbps, I guess that means it supports up to that speed. Slight problem I have is my pc is upstairs, quite far away from the router.. so I’m guessing the only option is to have it wired rather than Wi-Fi.
if there’s anything else you think needs changing, please let me know. Thanks, have a great day!
PCS SPECTRUM II COMPACT ARGB MID TOWER CASE (PWM) mATX
Intel® Core™ i5 Six Core Processor i5-12400F (Up to 4.4GHz) 18MB Cache
ASUS® PRIME H610M-A-CSM D4 (mATX, LGA1700, DDR4, PCIe 4.0)
32GB PCS PRO DDR4 3200MHz (2 x 16GB)
16GB NVIDIA GEFORCE RTX 4060 Ti - HDMI, DP, LHR
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW)
CORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY
STANDARD CPU COOLER LGA1700
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Microsoft® Edge
Monitor
AOC 27" 27B2AM - 1920 x 1080,4MS, HDMI
ASUS TUF GAMING M3 Mouse
Price: £1,283.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-home-office-pc-V/z6uVgJx8qS/
Microsoft® Edge
Monitor
