Advice for this gaming build
TheRedOne
Hello,
I would really appreciate some guidance on the below build. The parts I am most unsure on have red question marks beside them.
Use:
Gaming
Monitor:
https://www.amazon.co.uk/AOC-CU34G2...pcontext&ref_=fplfs&psc=1&smid=A3P5ROKL5A1OLE
--- Looking to upgrade to 4k at some point down the line
Budget:
£2.5k MAX
Case ??
CORSAIR 4000D RGB AIRFLOW TEMPERED GLASS GAMING CASE
Motherboard ??
GIGABYTE B650 AORUS ELITE AX V2 (AM5, DDR5, PCIe 4.0, Wi-Fi 6E)
32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB)
16GB NVIDIA GEFORCE RTX 4080 SUPER - HDMI, DP, LHR
Graphics Card Support Bracket
1st M.2 SSD Drive ??
Processor Cooling ??
CORSAIR ICUE LINK H100i RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
Firefox™
Price: £2,458.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/sg6DWktSYR/
If you're not changing to 4K in the next 12 months, then you can save £250 by going for the RTX4070Ti Super.
But here's where I'd be if we keep the 4080 Super in there...mostly the same, just some tweaks to RAM, PSU and storage config.
CORSAIR 4000D RGB AIRFLOW TEMPERED GLASS GAMING CASE - there are bigger & better cases for airflow/cooling, but I don't know your preference for RGB bling or any space constraints (plus it may cost more)
ASUS® TUF GAMING B650-PLUS WIFI (AM5, DDR5, PCIe 4.0, Wi-Fi 6) - changed as I trust Asus motherboards more than Gigabyte, and this is slightly cheaper to fit into the budget
32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB) - the sweet spot for AM5
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) - more reliable than the Samsungs, and you want to keep the boot/apps/game launcher drive clean of everything else
2TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 3325MB/sW) - larger, very reliable secondary drive for game installs, storage, etc.
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET - newer ATX3.1 spec PSU which means plenty of room for a GPU/CPU upgrade over the next 3-8 years
Firefox™
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) - full year of C&R for £5 extra
Price: £2,500.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/Pz!RMhCXyu/
Thank you very much!
I noticed you didn't change the processor cooler, would be this be efficient enough?
Yes, the cooler (2x120mm) is plenty as it's a very efficient CPU. Of course there's nothing stopping you putting a H115i (2x140mm) if you want the same performance at a lower RPM...or the H150i (3x120mm) if you want more RGB.
But I was trying to keep to the £1500 budget ;)
