Hi
I currently use a PC Specialist PC that I got in 2010, I don't have the money to buy a new one just now and it still works ok on the games I play, I was thinking about adding another 2GB ram to it to see if it would be a bit better in some of the newish games but not sure if I can just add 2gb or if I would need to replace the ram I have.
Pc Spec is -
COOLERMASTER HAF 922 MID TOWER GAMING CASE (£82)**SPECIAL**
Overclocked CPU
OverClocked Intel® Core™i7 Quad Core Processor i7-930 (2.8GHz @ max 3.8GHz)
ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
6GB KINGSTON HYPERX TRI-DDR3 1600MHz, INTEL X.M.P (3 x 2GB KIT)
2GB GTX 770
50GB OCZ VERTEX 2 SATA II 2.5" SSD (upto 285MB/sR | 275MB/sW)
2nd Storage Drive
100GB OCZ VERTEX 2 SATA II 2.5" SSD (upto 285MB/sR | 275MB/sW)
3rd Storage Drive
1tb WD blue
TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER
Sound Blaster® X-Fi™ Titanium - Fatal1ty Professional Series
Any advice would be great.
J
Pc Spec is -
Overclocked CPU
2GB GTX 770
2nd Storage Drive
3rd Storage Drive
1tb WD blue
J
