NoddyPirate
Grand Master
Just a quick one here:
My 5600X boosts to 4.65 GHz for single threaded loads and sustains just under 4.3 GHz when I am using all cores - referring to effective CPU clock - which is great and exactly what I expected.
However, I am noticing that once the CPU temperature increases above about 60-65 degrees the frequency slowly reduces - to a little over 4.0 GHz when it's in the upper 70's - or about 4% or so. I haven't pushed it higher than that. The CPU power draw slightly reduces also although much less so. It looks like it begins throttling quite early - I kind of expected that it would have sustained those boost to much higher temperatures?
Is throttling actually what it is doing? And does this match others experience with the 5600X?
No big deal either way of course - and it's still way above it 3.7 GHz base clock - I'll also never notice a 4% drop in performance for my workflow. But thought I'd ask anyway.....
