Hi
First my specs -
COOLERMASTER HAF 922 MID TOWER GAMING CASE (£82)**SPECIAL**
OverClocked Intel® Core™i7 Quad Core Processor i7-930 (2.8GHz @ max 3.8GHz)
ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
6GB CORSAIR XMS3 TRI-DDR3 1600MHz (3 X 2GB)
1GB ATI RADEON™ HD 5870 PCI EXPRESS - DirectX® 11
50GB OCZ VERTEX 2 SATA II 2.5" SSD (upto 285MB/sR | 275MB/sW)
100GB OCZ VERTEX 2 SATA II 2.5" SSD (upto 285MB/sR | 275MB/sW)
10x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
CORSAIR 850W PSU (TX850) 80+ ULTRA QUIET
TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER
ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND
Sound Blaster® X-Fi™ Titanium - Fatal1ty Professional Series
ONBOARD 10/100/1000 GIGABIT LAN PORT
Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence
Microsoft® Office Starter 2010 (Limited-function versions of Word & Excel)
MICROSOFT SECURITY ESSENTIALS - Free Basic Protection
LG W2753VC-PF 27" WIDESCREEN, HDMI/DVI-D FULL HD 1920x1080
LOGITECH X-540 5.1 Surround sound effect with full range and deep bass
I just received my PC today and when booting it up for the first time I kept getting this message
once this displayed and I hit enter to contine it restarted the computer and went through the process again and again. I hit F8 and it just restarted and showed the screen that says windows didnt close right and if I wanted to enter in safe mode etc but this screen was up for seconds before the computer restarted again, then for some reason after the 10th time of restarting it finally cam back up and stayed at the screen so I could pick pick load into windows normally and after that it started to load everything up, also when it restarted for the first time after I was in windows this message came up - The file is possibly corrupt. the file header checksum does not match the computer checksum. then it dissapeared and loaded me into win 7.
Do you know what these Error messages means and is it something that needs fixed? I have shut down and restarted now and everything seems to be fine but I am just a bit concerned that there might be something wrong.
any info would be great.
Also
I bought the LG w2753v monitor with this and by using the white DVI cable that came with it the screen uses the full area of the monitor but when I swapped it over to use HDMI it doesnt use the full display as there is a black boarder about 3 inches around the sides.... do you know why that would be? all the settings are the same with the DVI cable so I dont know why it would not be using the full screen to display the picture?
Other than those issues the pc seems great.
JJ
First my specs -
Also
JJ
