ASUS® TUF X570-PLUS GAMING WIFI (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
4TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 128MB CACHE
2nd M.2 SSD Drive
Received this build yesterday and I've noticed that with the H115i fans set to Quiet in iCUE my *idle* temps are above 60 degrees which seems crazy even for a Ryzen processor. On the balanced setting (which is very loud) idle temps are around 50c. In HWiNFO my CPU always seems to be boosting the clocks randomly even when not doing anything which probably doesn't help this. The only way I found to make it underclock at all was with the "power saver" plan in Windows but this doesn't seem to work correctly for boosting back up when gaming (even with min and max processor state set to 5% and 100% respectively inside the plan options.)
