3k or 4k option for The 17.3" Defiance coming?
agtrinity
Just checking, I would have thought the larger 17" models would be a better fit for the higher resolution screens
Why are those options not available?
Retron
Simple - there are no panels in existence.
http://www.panelook.com/modelsearch..._id&inch_high=18.1&resolution_pixels=38402160
http://www.panelook.com/modelsearch..._id&inch_high=18.1&resolution_pixels=28801620
Those are all the 4K and 3K laptop panels less than 18" in size. As you can see, there are some for 15" laptops (used by Clevo and others) but none whatsoever for 17" laptops.
Even if / when one does get made, it'll still take a while for a manufacturer to implement it in a laptop, so there'll be a couple of months' delay at least.
