Hi guys,
it's time for change of my old workstation and I have came up with these specs.
I am working mainly on 3ds max 2011 + vray 2.0 + Vue 10 xStream / Adobe Photoshop CS5. Other software: Adobe Premiere CS5 + After Effects CS5.
I know that working with quadro would be a dream but, just can't afford it and cpu + more memory would be better benefit. Standard card (non-quadro) still would cope with complex 3ds max scenes.
Limit was £1,200, but then I saw i7-3930K and it all changed. and now it's £1,480
Later I might O/C this workstation, which memory would be better for that 1333 vs 1600 ?
Case: COOLERMASTER CM690 MKII ADVANCED CASE
Processor (CPU): Intel® Core™i7 Six Core Processor i7-3930K (3.2GHz) 12MB Cache - that was a though choice between i7 2600k or Xeon E3-1230
Motherboard: ASUS® P9X79 PRO: INTEL® SOCKET LG2011
Memory (RAM): 32GB SAMSUNG QUAD-DDR3 1333MHz (8 X 4GB) - I am working on 16gb workstation at work and sometimes it's not enough. And 32gb would be futureproof
Graphics Card: 1.25GB NVIDIA GEFORCE GTX 560 Ti 448 CORE (Ltd Edition Superfast Card) - I have used to work on old Quadro FX 3450 but its nothing to compare to the new ones. I was thinking about Quadro 2000, but processing power and RAM is more prefferable. Workstation would be working day and night, and over weekends I will play some games, as a stress killer.
Memory - 1st Hard Disk: 2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm) - maybe after a year would add another 2gb drive for raid setup, and ssd for system
Memory Card Reader: INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply: CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
Processor Cooling: INTEL SOCKET LGA2011 STANDARD CPU COOLER - will add decent cooler ie: Noctua
Sound Card: ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities: 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options: 6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Operating System: NO OPERATING SYSTEM REQUIRED
Office Software: NO OFFICE SOFTWARE
Anti-Virus: NO ANTI-VIRUS SOFTWARE
Warranty: 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) (£5)
Delivery: STANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI)
Build Time: Standard Build - Approximately 8 to 10 working days
