Hi all,
I am considering buying a beast of a PC to invest and use for quite a few years. On the builder, with RAM i can get 32gb 3600mhz or can go allway up to 128gb 3000mhz. So what is best to do, go with quantity or quality?
Many thanks in advance, also is this overkill? i dont mind spending, if it worth it. Mainly used for gaming and music production on DAW like fruity loops which already do on laptop but does not cut it anymore so want to upgrade for both things.
First of all, the monitor from research that is best and potential future proof (4k gaming etc) I have seen is not available on here, called PG278QR ROG Swift 27" 2560x1440 TN G-Sync 165Hz Gaming Widescreen LED Slim Bezel Monitor Black. This does;
LED Backlit
2560x1440 Resolution
1000:1 Contrast Ratio
350cd/m² Brightness
1ms Response Time
1x DisplayPort
1x HDMI
G-SYNC
Height Adjust
3 Year Warranty
The PC --------------------
InWIN 703 MID TOWER GAMING CASE (BLACK/RED)
Intel® Core™ i7 Eight Core Processor i7-7820X (3.6GHz) 11MB Cache
Gigabyte X299 AORUS Gaming 3: ATX, USB 3.1, SATA 6 GB/s
64GB Corsair VENGEANCE DDR4 3000MHz (4 x 16GB)???????????????????
11GB NVIDIA GEFORCE GTX 1080 Ti - HDMI, 3x DP GeForce - GTX VR Ready!
Get Destiny 2 with select GTX 10 Series GPUs! ** Limited Codes Available **
1st Hard Disk
NOT REQUIRED
M.2 SSD Drive
512GB SAMSUNG 960 PRO M.2, PCIe NVMe (up to 3500MB/R, 2100MB/W)
2nd M.2 SSD Drive
1TB SAMSUNG SM961 M.2, PCIe NVMe (up to 3200MB/R, 1800MB/W)
CORSAIR 650W TXm SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
CoolerMaster MasterLiquid 120 High Performance Liquid Cooler
LED Lighting
50cm Red LED Strip
Fan Controller
NZXT GRID+ V2 Fan Controller with upto 5 Fitted Case Fans
Creative Sound Blaster® Audigy Rx
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
LED Backlit
350cd/m² Brightness
1ms Response Time
1x DisplayPort
1x HDMI
G-SYNC
Height Adjust
3 Year Warranty
1st Hard Disk
NOT REQUIRED
M.2 SSD Drive
2nd M.2 SSD Drive
LED Lighting
50cm Red LED Strip
Fan Controller
