just wondered if there is a differance between all the differant suppliers of this card other than the £40-£50 price varience, and which one pcs use to build your machine with??
its only because there charging £459 for it and you can pick a palit one up for £399. now £60 could buy you something else. people go on about not doing the express build to save you £39 and pcs are charging over the top for a GC. i was told that they were good value and the cheapest??
They are good value in my opinion. If you buy the card from a third party you need to get the RMA sort it with them and that could take a while, when I had an issue with my GPU a new card was given and replaced in less than a week. You may find some components cheaper in another sites but the quality of service provided is second to none.
