17" Laptop Advice Please
TJC
Hi I will be buying a new laptop in the next month or two, budget is around £1200ish. I mostly watch multiple streams of sporting events (including external monitor), the odd VM, bit of VB, game wise the most demanding game would be RUSE, laptop will be desk bound and only moved around 3 times a year so weight or battery life not an issue.
Optimus Series: 17.3" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-4700MQ (2.40GHz) 6MB
16GB SAMSUNG 1600MHz SODIMM DDR3 MEMORY (2 x 8GB)
NVIDIA® GeForce® GTX 765M - 2.0GB DDR5 Video RAM - DirectX® 11
Memory - Hard Disk
240GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
Bluetooth & Wireless
GIGABIT LAN & KILLER™ 1202 WIRELESS GAMING 802.11N + BLUETOOTH 4.0
Optimus Series 8 Cell Lithium Ion Battery (5,200 mAh/76.96WH)
Power Lead & Adaptor
OPTIMUS SERIES UK KEYBOARD WITH NUMBER PAD
Notebook Mouse
Dead Pixel Guarantee
1 Year Dead Pixel Guarantee Inc. Labour & Carriage Costs (£19)
Insurance
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 12 NOON) (£19)
£1,136.00 inc VAT
I think the Optimus V is the one for me, BUT I am a bit concerned (paranoid) about the fan and screen brightness issues.
Would you recommend getting the Optimus anyway (as a future bios will correct this), or spend a bit more and get something like a Skyfire?
I am not much of a gamer, so would the Skyfire be overkill? As the extra USB is the only real benefit I can see.
Can the Optimus power 3 screens? Its own 17” and two monitors via HDMI and VGA?
I am currently using an Acer 5553G, any advice would be appreciated thanks.
The optimus is a great chassis, definitely a good choice.
I don't think you can but for an official response you may want to contact PCS.
TJC
Thanks keynes, spec wise look ok?
For what I will be doing more RAM or better CPU wont have any huge effect?
TJC
Hi Slim, I did have a look at it I am still in the research phase do you think the differences I have in mine are worth the extra money?
