Hey guys,
So I am looking to buy my first proper gaming rig, and I have decided to make it portable and have opted for the Vortex IV. Now I practically have decided my budget will be £1,500 although I will happily go a bit higher because I'd rather buy what I want and not have a reason to make me want to spend this sort of money again for a while.
I would like some help with some small decisions, based on what I have seen around these forums and just general things I do not know about, if you don't mind.
Remember, this is for a gaming rig, which I will also use for some heavy applications, such as editing and recording 1080p HD Footage, so please answer with that in mind.
Thank you in advance.
- What screen would you recommend? I have heard Matte has less glare but also less brightness, but have noticed many of you have opted for Glossy.
- I must've had tunnel vision because in my head the faster clock speed on a processor the better, but it appears as though many of you have opted for the i7-4700MQ, which is the slowest one. Why is this? Should I not be concerned so much about clock speed and just opt for any as long as it is a Quad-Core i7 at least?
- What are the advantages of Kingston Hyper-X Genesis memory? If I opt for just 8Gb (2x4Gb) memory for now, would I be able to add more at a later date? I am pretty sure you can, as I have in the past, but this is my first PC Specialist order.
- Is the choice between AMD Radeon HD 8970M and NVIDIA GeForce GTX 780M purely choice or is it always better to go for the better benchmark-scored graphics card? Does the CPU affect GPU/graphics performance?
- If I opt for a SSD drive or a Hybrid drive, am I correct in thinking I wouldn't require an mSATA SSD Cache?
