17.3" Defiance VI - Gaming?
Adjust91
Morning,
Just wanted to check that the below spec will be fine for gaming anything from low quality games to high quality. Won't be used often, once or twice a week, but it'll be used for 6-8 hour sessions when it is used.
I debated between this and the optimus but have read that the Defiance has a sturdy base/keyboard so it should last much longer than the optimus.
Does anyone know what the upgrade options are on the Defiance IV 17.3"? I'm going for only 1x 8gb ram as I'll get another 1x 8gb later on to add into it, so I presume one of the upgrade options is the RAM. Are the others just the HDD/SDD?
thanks,
Defiance Series: 17.3" Matte Full HD 120Hz LED Widescreen (1920x1080)
Intel® Core™ i7 Quad Core Processor 7700HQ (2.8GHz, 3.8GHz Turbo)
8GB Corsair 2133MHz SODIMM DDR4 (1 x 8GB)
NVIDIA® GeForce® GTX 1060 - 6.0GB GDDR5 Video RAM - DirectX® 12.1
1st Hard Disk
1TB SERIAL ATA III 2.5" HARD DRIVE WITH 32MB CACHE (7,200rpm)
M.2 SSD Drive
256GB SAMSUNG PM961 M.2, PCIe NVMe (up to 2800MB/R, 1100MB/W)
AC Adaptor
1 x 200W AC Adaptor
2 Channel High Def. Audio + MIC/Headphone + Sound BlasterX® Pro-Gaming 720˚
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® AC-8265 M.2 (867Mbps, 802.11AC) +BT 4.0
4 x USB 3.0 Ports + 1 x USB 3.1 Type C Ports
Defiance Series 4 Cell Lithium Ion Battery (66WH)
RGB BACKLIT UK KEYBOARD
Notebook Mouse
Price £1,296.00 including VAT and delivery
