I've wanted a decent gaming laptop for a while and from the ones I've seen on PCS, I think these are my best two options, although I would like feedback and opinions.
Vortex Series: 15.6" Matte Full HD 144Hz LED Widescreen (1920x1080) + G-Sync
Intel® Core™ i7 Six Core Processor 9750H (2.6GHz, 4.5GHz Turbo)
16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1TB SEAGATE 7mm SERIAL ATA III 2.5" HARD DRIVE WITH 128MB CACHE (7,200rpm)
256GB INTEL® 760p M.2 NVMe PCIe SSD (upto 3210MB/sR | 1315MB/sW)
AC Adaptor
1 x 230W AC Adaptor
Vortex IX Series 6 Cell Lithium Ion Battery
Bluetooth & Wireless
1 x USB 3.1 PORT (Type C) + 2 x USB 3.0 PORTS + 1 x USB 2.0 PORT
Recoil Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Integrated 3 in 1 Card Reader (SD / SDHC / SDXC)
AC Adaptor
1 x 230W AC Adaptor
Recoil II Series 46WH Lithium Ion Battery
1 x 1 Metre European Power Cable (Kettle Lead)
I would like to know which one is my best option? Both specs are around the same price at just over £1600. I have noticed that the Vortex has G-Sync, how much of a difference does this make and is it worth it for the slightly smaller display?
I've also read that PCS are apparently bringing out new panels for some laptops too, does anyone have any more info on this?
AC Adaptor
1 x 230W AC Adaptor
AC Adaptor
1 x 230W AC Adaptor
