15.6" RTX 3000 series laptops at PCS.
Bhuna50
Just a quick comparison for people to see whats available PCSPECIALIST - 15 inch Laptops for Gaming, Custom Laptops :
It should be noted that you should not take these as gospel when making your decision and prices are as per when I did this (13/1 9am ish). This was put together reasonably quickly to help as a guide only - you should ensure you check all specs and configurations yourself when ordering - I do not work for PCS or represent PCS in any way.
A similar thread can be found here showing you the 17.3" laptops:
17.3" RTX 3000 SERIES LAPTOPS AT PCS. | PCSPECIALIST
