Hi all.
I need a 15" laptop for the usuals, browsing, plunging into the TV for btsport plus moderate gaming
My laptop games of choice will only be X3 Terran Conflict (which even hd4000 can handle a bit) but also Skyrim which I'd like to run pretty maxed out (I save Rome II and the like for my PC).
Soooo my questions.
I've been looking at various options, the 15.6 Cosmos II (850m) / Optimus V (860m)
1 Would the Cosmos II handle Skyrim pretty much maxed out on IPS 1920x1080
2 Would the Cosmos II be a better choice due to weight (as I'll be using it in flight and therefore lugging around)
3 Are there big differences in noise/heat/casings and power birck size between the Cosmos and Optimus
My gut is that the Cosmos would be better due to taking it on flight and having a PC for my main gaming and if it was GDDR5 then I wouldn't even be asking as I'd snap it up straight away but any pointers would be appreciated. Notebookcheck seems to indicate the 850m GDDR3 should be good enough but hearing from owners would be better.
Thanks all.
Soooo my questions.
Thanks all.
