Hello due to a house fire i am in need of a new pc, I'll be using 2 27inch 1440p monitors at least 165hz+ (I've not decided which yet)
My budget is around £3000-£3500 I'd rather not spend more than £3500
The pc will be used for Gaming, Livestreaming, and video editing, So it is expected to be heavily used daily.
Other notes, I don't care for RGB I just picked the case because people told me it's a good case for airflow and a good case in general, if you have any other case suggestions that are good or better let me know, that goes with any other parts or things I should add/change thank you.
CORSAIR iCUE 5000T RGB MID TOWER GAMING CASE
Promotional Item
Buy select GeForce RTX 40 Series*, get Star Wars: Outlaws
AMD Ryzen 9 7950X3D 16 Core CPU (4.2GHz-5.7GHz/144MB w/3D V-CACHE/AM5)
ASUS® TUF GAMING X870-PLUS WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
64GB Corsair VENGEANCE DDR5 6000MHz (2 x 32GB) KIT
16GB ASUS TUF GEFORCE RTX 4070 Ti SUPER OC EDITION - HDMI, 3 x DP
CORSAIR ICUE LINK H150i RGB HIGH PERFORMANCE CPU COOLER
4 x 120mm Thermaltake TOUGHFAN 12 Case Fans
ONBOARD 2.5Gbe LAN PORT
Firefox™
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/wne2H67zZ0/
Promotional Item
Firefox™
