Need some help to iron out some final decisions with this build.
Budget is £1800ish
My main dilemma is whether or not to bump the GPU up from 6800xt to the 6950xt. The increase in price isn't very much. The vast majority of threads and forums on this exact issue have said upgrade to the bigger one, for more money than the difference here on PCS... However I don't know if I really need that much firepower and wonder how much more I'd be spending long term regarding power usage. (If anyone has any reassuring underclocking/power limiting advice, that could make or break this decision.)
Power supply - Opinions needed, especially with the unconfirmed choice of GPU.
RAM Speed - Opinions please.
Coolers - I have very little knowledge on this, of what's sufficient, what's overkill. I don't need the brightest flashing lights. Send help.
Feel free to critique whatever else!
Thanks in advance!
CORSAIR 5000D AIRFLOW TEMPERED GLASS GAMING CASE
Promotional Item
Get Last of Us: Part 1 when you buy select AMD Radeon™ RX graphic cards!
Processor (CPU) - Vs the 7700x?
AMD Ryzen 7 7700 Eight Core CPU (3.8GHz-5.3GHz/40MB CACHE/AM5)
Motherboard - Or ASUS TUF?
GIGABYTE B650M DS3H: DDR5, USB 3.2 - ARGB Ready!
Memory (RAM) - Speed? Sweet spot?
32GB Corsair VENGEANCE DDR5 4800MHz (2 x 16GB)
Graphics Card - Vs 6950xt?
16GB AMD RADEON™ RX 6800 XT - HDMI, DP - DX® 12
1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
Processor Cooling - HELP
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler (AMD)
2x 120mm Black Case Fan
NO RECOVERY MEDIA REQUIRED
Price: £1782 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/MuPeMDWXPk/
Budget is £1800ish
Thanks in advance!
Promotional Item
