What kinds of games?I have no ide witch one should buy. Wanted lg ultrageat from currys but i was late.
Looking for 1440p 144hz or more.
Sugestions and opinion please
That's quite a small budget to suit the 3070, would get you an entry level screen, but I'd suggest upping the budget to 400 - 500 to get something better suited.Any games buying pc after 15 years brake. Budget i don't know want 300 400
It might help if you say what sort of size you want/restrictions then. I must admit i thought you were after an "Ultrawide" monitor, @SpyderTracks the OP was looking at the LG Ultragear, odd name but meh.I.don want utrawide , no.space
You can pre order the LG here for despatch on Wednesday:I.don want utrawide , no.space
You just need to do a Google search then. I’m not sure what you’re looking for.Lg is amaizing but it was 339 in currys:/
I.thing about this asus aswell but i.want compare more options size 27-32
