Citrus_9
Expert
Hi guys, I'd appreciate if someone have a look at the below build I'm thinking to purchase and give some thoughts as I keep upgrading or downgrading my choices as struggling to make a final decision.
I'd get a 1080p 144Mhz 24-inch IPS monitor separately (thinking of AOC 24G2U/BK or ASUS TUF Gaming VG259Q).
A PC would be for:
CORSAIR 275R AIRFLOW TEMPERED GLASS GAMING CASE
6GB AMD RADEON™ RX 5600 XT - HDMI, DP, DX® 12
2TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 128MB CACHE
ASUS PCE-AX58BT Wi-Fi 6 (802.11ax) 2400Mbps/5GHz, 600Mbps/2.4GHz
NO RECOVERY MEDIA REQUIRED
Promotional Item
Get Godfall and/or WoW:Shadowlands w/ select AMD Radeon Graphics
A PC would be for:
- Games: Mafia 3, GTA 5, Cities Skylines with a some mods and I may be listening Spotify while playing.
- Chrome or Firefox would be always opened with around 15-25 tabs and listening music while browsing or playing Netflix in the background.
- Watching Netflix same time while using Excel, Word and Outlook with also a few pdfs and jpgs keep opening and closing.
- I want to stick with AMD CPU and GPU can be AMD 5600XT or NVidia 1660Ti or even 2060.
- I'm mostly concerned about a CPU (3600 vs 3600X vs 3600XT or even take a 3700X)? With a 3700X I could stretch a budget to 1700 or 1800 Euro, but do I really need 3700X?
- I've read that 3600XT tends to have higher temp comparing to 3600X or even 3700X, but not too sure if it's true. Either way I'm taking air cooler Noctua as I want it to cool everything well and be fairly quiet.
- I could take RAM 3200MHz, but don't know if it's worth to spend extra money on that.
- I'll use M.2 for Win10 and the question about HDD which I'd use for all files and games: I've read that Ironwolf is much more reliable comparing to Barracuda but should I spend extra for NAS thinking it's better? I was keep thinking about a secondary drive to be between 2TB and 4TB and whether or not HDD or SSD. If I take HDD, I'd prefer Ironwolf, if SSD - Samsung. I finally decided that 2TB should be enough to me... Is Ironwolf ok to use in a desktop PC used for around 10-12 hrs daily but always being shut down for a night? Or better to put sleep with NAS HDD in a PC?
- PSU I've chosen 750W just because it's RMx, but maybe I should save a bit and take a 550W TXm?
- About a sound card at first I thought to get an Asus Xonar 7.1, but changed the mind as I saw someone recently in this forum suggested that a built in 5.1 is good enough in general.
- About WiFi I'm also finding hard to choose between INTEL® Wi-Fi 6 AX200 and ASUS PCE-AX58BT 802.11ax. Currently I have at home a Virgin Media up to 500mbps/50mbps wifi which mostly is just around 150-300mbps/45mbps. I need a reliable bluetooth with a wifi card too and struggled to find if INTEL® Wi-Fi 6 AX200 has a bluetooth? I was trying to compare online INTEL® Wi-Fi 6 AX20 vs ASUS PCE-AX58BT 802.11a but couldn't find much. My wifi modem is downstairs in the far end of the house and thinking that Asus would be better in my case.
- Should I get extra case fans? I've chosen a CORSAIR 275R purposely because of a decent price and 2x 120mm front fans included + 1x 120mm rear fan included. Maybe I should take an extra 120mm Thermaltake TOUGHFAN 12 Fan for front or top?
Promotional Item
PCSPECIALIST - Top Spec Custom PCs & Laptops Built to Order
Manufacturer of performance custom computers and laptops. Customise your ideal gaming PC or laptop using our advanced configurator.
www.pcspecialist.ie
