10700k cooling
Fabian03
So im planning to buy a system in may with the following specs
Case: coolermaster td500
Mobo: asus rog strix z490 f
Cpu: 10700k
Gpu: asus rog strix 3080
Ram: 2x16gb 3200mhz
Storage: 1tb hdd
Paste: artic mx4
Im unsure on if the pcs frostflow 240 would be up to the task of cooling the 10700k under a heavy gaming load.
I plan to use this pc for gaming primarily and I know some of the specs are overkill for that purpose but my point is about the cpu cooler so any help on that front would be greatly appreciated my budget is £2300 vat included.
Deleted member 17413
Its an Intel chip, you want the best cooling you can find on it.
They run hot before you even look at the rest of a system....
I would also advise reading through the links in here before placing any actual orders, Intel would not be advised as a build platform, they're underperforming by quite a bit.
