Sanjeet
Haha that is exactly what I was doing too to find out about the card. And yeah I agree with everything you’ve just said 😂. I think I’d prefer to have an rtx and I’ve been waiting about 4 months already so what’s a few more right? Like you said don’t wanna rush into a decision. Thank you for your time and help. Very much appreciated“I don’t know much about the AMD GPU’s”. Realistically I’m in the same boat. Checking benchmarks is about the only way to gauge it for me. It never seems to be below the 3060TI it’s generally between the 3080 and 3070 from memory. As we normally recommend a 3070 to max out a 1440p 144hz monitor the 6700XT will do an amazing job at it and may be considered overkill, but it is also £30 cheaper at its current price so represents great value. (I wouldn’t be surprised if that shoots up). I normally use all of Tech Spots reviews for benchmarks as it shows it against a great range of cards on a number of games. Their review can be found here
As @SpyderTracks has said, you’ll be waiting a while anyway. Due to the sheer amount of orders there’s just a long queue. There’s a chance that they’ll do the same for the 6700XT as they did for the 3060 and get orders out very quickly when they had stock of that card to try and reduce the average wait times a bit, but I don’t want to say I know they’ll do that, because I obviously don’t.
The other thing that should be a consideration, is that the 3060TI can’t even be ordered right now. Why that is I’m unsure, maybe to reduce the queue size a bit, maybe they didn’t know when the next delivery was going to be so put orders on hold. Realistically that’s speculation from me and it could be any number of reasons.
What I’d say is go for the build you want and accept the wait. If you want a 6700XT go for it. If you’d rather a 3060TI, just take the wait. If you play your cards right, that PC that should last you 6 or more years if upgraded correctly so in the grand scheme of things, A few month wait is not a lot of time. Plus you’ll be happier in the long run when you go for the spec you actually wanted over one you got to get the PC quickly.
