£800 budget for gaming rig - Any ideas?
nhornby51743
I'm looking to build a new rig for between £600-800 and there's a few things I'd like clarification on. Firstly here's the spec I was thinking;
COOLERMASTER ELITE 311 BLUE CASE
AMD FX-6300 Six Core CPU (3.50GHz/8MB CACHE/AM3+)
ASUS® M5A97 (DDR3, USB3.0, 6Gb/s)
8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
2GB NVIDIA GEFORCE GTX 760 - 2 DVI, HDMI, DP - 3D Vision Ready
500GB 3.5" SATA-III 6GB/s HDD 7200RPM 16MB CACHE
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Super Quiet 22dBA Triple Copper Heatpipe AMD CPU Cooler (£19)
1 x 12CM Black Case Fan (configured to extract from rear/roof) (£5)
Total inc. VAT - £629
As for clarifying a few things, here's what I'd like to know
1. Amd FX6350 or Intel i5 for the processor?
2. Is it worth getting 16gb RAM over 8gb?
3. For 1080p gaming should I get the gtx 760 or 770.
I don't intend to overclock my system and I'd like the build to offer decent fps on high settings on newer games like Crysis 3/Metro/Battlefield.
Replies appreciated, Many thanks
For your budget getting the GTX 770 would be compromising on other components. For a gaming rig you may want to consider a much better case for cooling/airflow. If you have a budget of around £1000 I'd suggest an i5 + GTX 770, for your budget FX-6350 + best gpu you can afford.
nhornby51743
Any ideas on the case as I don't really want to be spending more than £60 on a case. I looked at the InWIN Mana 136 and it looks like it could be sufficient. Sorry for all the questions, I'm a noob and just want as much advice as I can get :)
The inwin Mana, Corsair 200r or PCS Maelstrom.
