£650 Gaming PC
hi can someone build me the best gaming pc possible for around £650, preferably intel but i know that's a long shot with the budget. thanks!!!!!
sted
Rising Star
It's a tight fit, but you may be able to have it squeezed in, other than that you may have to settle for AMD. You won't get too far in terms of modern gaming, even moreso with releases to be, it won't be future proofed much at all, so my personal advice is save up some more money and aim for a build at a minimum between £800-1k, anything more you manage to save to can only improve the rig and make it last a fair bit longer than one under your current budget.
Of course, I realise you may not for some reason have this kind of choice, but it is just a suggestion after all. If you are eager to just go with that budget, someone is sure to come along to help you with it (I would, but admittedly not the best with speccing, ESP with a low budget, I tend to see a lot of things and end up adding them all and effectively doubling or even tripling the price! :D)
vanthus
Member Resting in Peace
Edit,with no operating system
InWIN MANA-136 BLACK GAMING CASE
ASUS® P8Z77-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
4GB SAMSUNG DUAL-DDR3 1333MHz (1 X 4GB)
2GB NVIDIA GEFORCE GTX 660 - DVI, HDMI, VGA - 3D Vision Ready
500GB WD CAVIAR BLACK WD5003AZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
INTEL SOCKET LGA1155 STANDARD CPU COOLER
Price: £647.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-ivy-bridge-pc/5JEfDN6pmv/
