£4000 to spend help???
eyresey
Hi all,
I have a really great PC that use for gaming, my friend chose all the spec and now I need a new one and my friend is too busy to help. I have £4000 to spend on a PC what is the very best PC I can get? I will need to be able to play games obviously, stream and edit video. Thanks in advance. I9 is my prefence. don't know what else to say?
Hi all,
What are your current PC specs?
What monitor are you pairing it with, what resolution and refresh rate or make and model if you're unsure?
eyresey
I7
16gb ram
GTX 770
Anything else I need to put?
240hz for sure and I think 4k but I could be wrong.
Sorry I am not the best with these things.
having read through it seems to be that I should wait and get the new AMD ?
that's what it was called.
Cool, so that's 1440p 240hz, so the 3080 would pair well with that.
An AMD processor would be far far better than an i9 in all areas but quite literally bundles more performance for streaming and editing especially.
I would personally wait for AMD's announcement of their new processors on 8th October if you can wait til then. Stocks of the 3080 are going to be in short supply for a while anyway so you would likely be waiting past that time anyway if you were to order now.
But as an example build:
AMD Ryzen 9 3950X 16 Core CPU (3.5GHz-4.7GHz/73MB CACHE/AM4)
ASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
10GB NVIDIA GEFORCE RTX 3080
2TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 128MB CACHE
250GB SEAGATE BARRACUDA 120 2.5" SSD, (up to 560MB/sR | 540MB/sW)
Capture/Streaming Cards
Elgato Game Capture 4K60 PRO MK.2 - PCIe Card
Streaming Accessories
Elgato Stream Deck
Home Installation
NONE
Price: £3,261.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Waj87JV8s8/
forget the monitor get 3090 gpu 64gb ram which will help with editing and what ever the latest i9 processor available and make the ram is the fastest going ohh and some RGB so it looks cool
eyresey
Given your budget I would also consider upping the GPU to the 3090 when it's in stock at the end of this month.
Thank you for the reply, that's brilliant, I will wait until the 8th october then in that case, I am not in a rush, I have a PC now to play on and can wait a couple of weeks. I will also get the 3090 as it willl be available and still fits in my budget dependant on the AMD costs. do yu mind if I reply to this when the new announcments are released?
So I can get your opinion. you seem well informed and very knowlegeable in this subject.
Of course, post back when the AMD CPU’s have been announced, the 3090 will be available then also.
How much video editing are we talking about? What would take preference for you, would it be gaming or would it be editing?
I'm surmising that the editing will relate to the recording of the gaming you have been doing and likely uploading to YouTube and the likes? If that is the case then I would probably go down the 3900XT route over the 3950X. The 3950X is a processing monster, absolutely no doubt, but I think the 3900XT would eek it out in gaming as it won't drop quite as low on all-core usage. There's likely to be very little in it, don't get me wrong, but there is a big difference in value between the 2 when gaming is considered. If the editing is a high priority then the 3950X is a no brainer at this budget.
eyresey
So video editing, would be fairly minimal to be honest, it's not even for my YouTube videos, it's just my friends videos of free running he asks me to edit them every now and then, I don't YouTube, I just stream for friends.
The one Spyder built wasn't even near £4000 to be fair so I can hold out at the minute and see what you both think after October 8th, decide from there, I'm not in a rush, I just think it's time for an upgrade and I've been saving for a while now to get to this point.
eyresey
With £4k to spend I would be aiming for a new monitor too. A Super Ultrawide would be on my shopping list (Probably a G9).
£4000 is for computer, I have other money to spend. I am not changing my monitors just yet as I am also buying a new motorbike and a driving simulator set up!
You won't need £4000 for the computer, won't add any benefit. These cards a much cheaper than their predecessors.
eyresey
It's just a budget, I don't have to spend all of it but I think I'm going to get the 3090 and wait and see what the new AMD processors are
eyresey
Hiya! Me again, so the new AMD processors look really good, I have decided the 3090 is the one I want to get, would you recommend the new AMD processor?
