£2,000 budget for high end professional machine - Need Advice
Dean_Moriarty
Hi all,
I'm currently looking to purchase a new PC with the following considerations:
  • High end professional work in a multitasking environment that requires a large amount of RAM (>32GB) + good CPU (esp for single core)
  • At least one fast SSD over 1TB in size
  • Light to medium gaming for strategy / simulation titles (I have a console for AAA games)
  • A small form factor is a must (Mini tower would be ideal, but open to other suggestions)
  • Windows 11 Pro, Wi-Fi, Bluetooth and >6 USB 3 / USB C
  • Ability to support two 4K displays (easy to meet)
  • Long term use without getting too loud / hot
  • I have a stretch budget of £2,500 if needed
I'm conscious the below is overkill but this is what I built to meet the budget I have. However, I have some concerns around the cooling of this system (There isn't an option to upgrade the cooler further) and I'm sure that there are ways to reconfigure / create a new build that would better match my requirements within the budget.
I'd appreciate any advice on how to build something within the requirements above.
THERMALTAKE CORE V1 GAMING CASE (BLACK)
Intel® Core™ i7 16-Core Processor i7-13700 (Up to 5.2 GHz) 30MB Cache
ASUS® STRIX B660-I GAMING WIFI (DDR5, USB 3.2, 6Gb/s) - ARGB Ready!
96GB Corsair VENGEANCE DDR5 5600MHz (2 x 48GB)
8GB NVIDIA GEFORCE RTX 3050 - HDMI, DP, LHR
PCS FrostFlow 120 Series RGB High Performance Liquid Cooler
Price: £2,000.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-sff-gaming/jGZPs7dq7Z/
I would strongly advise against a SFF system. They aren't ideal for anything even remotely high end. First draft below. Covers all your requirements.
With the budget in mind it may be worthwhile looking at an AM5 build. You would get a much more future proof system where you could upgrade the CPU. If it's going to be a one and done build, the below has you covered. You may want to consider the 13900K but you would likely need more cooling to take that chip on.
Intel® Core™ i7 16-Core Processor i7-13700K (3.4GHz) 30MB Cache
ASUS® PRIME B760-PLUS D4 (LGA1700, PCIe5.0, USB 3.2)
64GB Corsair VENGEANCE DDR4 3200Mhz (2 x 32GB)
8GB AMD RADEON™ RX 6600 - HDMI, DP - DX® 12
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W)
2TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6900MB/W)
CORSAIR iCUE H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Microsoft® Edge
Standard Build - Approximately 14 to 16 working days
Price: £1,947.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/4yCG!K9BJC/
